Outboard help
Mavric
8 Mar 2012
Birmingham
Could someone tell me the year m yamaha 60hp 2 stroke is and any other info please if ive read it right the p in the lower left corner means 2004 ? and what is 6F0 ? cheers in advance
Yamaha codes are a bit of a mystery to me
The date letter codes ( which may be in bottom right or bottom left of the ID plate ) have been recycled so a "P" could be 2004 or 1983... Although some listsr say "P" is 1991. It seems to depend on which part of the world you are in
As for "6F0" ..... If you had said that the model code was F60 I would have said it indicated a 60 hp four stroke......... but I guess you know if you have a 2 stroke or a four stroke, at least I hope you do!
Maybe your best bet is to make a note of all the letters and numbers on the ID plate and pop into your nearest Yamaha outboard dealer.
