FairweatherDave
Yes. I've never done it before. The time has come. Reassembling my outboard with a new headgasket and blue hylomar ( a non-setting gasket sealant).
Q 1. A thin bead or smear all over very thin with a finger?
Q 2. My inclination is to be pretty gentle tightening up the bolts, having had the shearing off issue when undoing the leg. The bolts are greased. I am aware you should retighten a while after the initial tightening but what sort of torque, or should I use common sense, be gentle but firm and just look for leaks?
Q 3. Once tightened up can I fire up the engine straight away?
Really appreciate the advice I get here, even when it conflicts
Cheers
Dave
Cheers
Dave
