Outboard fuel fittings
markpoint
29 Dec 2006
I have an old Yamaha 5hp Aux Outboard that appears to have a Suzuki engine fuel connector bolted to the lifting round bar. The OD of the connection is 10mm, the accepting recess is set back 5mm, then another 5mm to the hex bolt. Thre is a 6mm fuel line barded connector to take line to carb. Any ideas
what female connector I need, I'm a bit tired to viewing chandlers websites the no images / dims - and buying kit that does not fit....... /forums/images/graemlins/confused.gif
Well....
Take the bits off that you have back to rubber hose and go to your nearest multi brand dealer and do a bit of research. Buy the bits that will connect to your tank and away you go.
Steve Cronin
Best is to go to Outboard service and check ... if different - then buy the male and female combo to correct it to proper fittings ...
or
if you want to keep the fittings you have - then it's a motorbike service place ?????
