VicS
If you were to attempt to test the output from an outboard engine charge coil before the rectifier using a digital multimeter set to an AC volts range would you expect to get a meaningful reading or would the meter just not respond to something so far removed from a sine wave?
If a digital meter doesn't work an analogue one would wouldn't it.
The evening is young ... anybody with an outboard handy at a loose end?
