120379
New Member
Hi everyone,
I have just recently purchased a 14ft Marina speedboat with Yamaha 55ae 663 engine on it. Nice tidy boat except the engine cuts out after about 25mins of use. Then letting it sit for about fifteen mins the engine will eventually start again and then we take it back in. Checked the fuel filters and found a lot of water sitting in them. One after the tank had about 75% water in it. And the one in the engine had water in it as well. Flushed these out and put it back together. Took it out again and it ran fine for about 25mins again and just died. Paddled over to a buoy and waited for about 15 mins then got it goin again with fast idle on. Took it back in. It appears to pump water very well, and has apparanly been recently serviced.
Any ideas whats goin on??
I am goin to strip the fuel tank and drain it thoroughly to make sure there is no more water in there. And also empty the carbs.
Hopefully this will sort it out.
Any advice or ideas welcome!! Bit of a dampner on the heat wave coming! Want to get out in her!!
