Deefor
I'm re-posting this thread that I started in the PBO section in the hope I'll get a few more replies in the MoBo section. Yes, I'm still confused
I've recently purchased a split charging diode (input + 2 out) for use with my 15hp Tohatsu outboard as I wish to install a leisure battery in addition to the starter battery.
Currently (with just one battery), the alternator charge lead output goes to the +ve on the starter battery via a simple key operated on/off switch to enable both starting of the engine and charging of the battery. I understand how to wire the new/additional leisure battery but not how to wire the starter battery via the split charger.
All the wiring diagrams I've found on the net pertain to inboard engines with an alternator and starter motor and I'm somewhat confused as to how it all works. The nearest thread I've found is http://www.ybw.com/forums/showthread.php?t=84456 but I'm still unable to understand everything when relating it to an outboard.
Any help would be appreciated .
Many thanks .
Many thanks .
