JumbleDuck
I spent a cheerful hour or two poking around under my wee Hunter today. This is what I found.
There are hundreds and hundreds of blisters between the paint and the gelcoat. These are typically 3 - 6mm across and perhaps 1 - 3 mm high. When burst a clear fluid smelling strongly of acetone comes out. Underneath the paint the gelcoat is completely unblistered, but under perhaps half of the paint blisters there is a small hemispherical pit in the gel coat, typically 1mm deep. It's not impossible that there are pinholes under the blisters which don't have obvious pits.
The boat is about 40 years old and has done three seasons on a freshwater loch after 20 years ashore.
The only alternative to osmosis I can imagine is some strange reaction between the Trilux I put on when I recommisioned her and the old paint underneath, but the fluid filling to the blisters makes that seem unlikely. If it is osmosis, it seems to be finding it easier to squirt out through pinholes than to push off the gelcoat, which I find reassuring.
My plan is to strip it down to the gel coat, fill all the pits and repaint. It wouldn;t be worth a full osmosis treatment even if I could afford it and was worried enough to contemplate it.
Opinions welcome.
Opinions welcome.
