Optimum height for A/S loop?
colind3782
18 Jan 2011
Shropshire/Empuriabrava
What's the optimum height for the anti-syphon loop on the heads outlet. Above the waterline obviously but not so high that the pump can't handle it?
It's straight out with no holding tank.
The pump will handle it easily. Where the toilet is always above the heeled waterline, Jabsco specify at least 30cm of pipe above the natural waterline. Where the toilet is below the waterline, Jabsco specify at least 20cm of pipe above the heeled waterline. In practice, it's difficult to determine the heeled waterline with accuracy, so I'd err on the side of caution! There are good diagrams in the Jabsco toilet manual.
Thanks for that. It's a Matromarine toilet and the waterline is just below the toilet rim. I'll have a look at the Jabsco manual before I fit the loop.
The more inboard the loop, the less height needed. My inlet loop is only about a foot above the bowl but is near the centreline. My holding tank functions as my outlet loop but on our Sadler it went up to the deck level and the pump coped alright.
It might be worth considering the amount of fluid trapped on the "up" side of the pipe because you will not be able to clear it & if the pump valve leaks a bit it MAY run back into the bowl. If it is also stored in the pipe which is not a good sanitary hose it MAY lead to additional smell & it MAY lead to a long length of pipe build up of calcium if left to long to stagnate in the pipe. A smaller loop will hold less fluid- possibly
As the toilet pumps straight out to sea, rather than to a holding tank, there's no reason not to pump sufficiently to ensure that the pipe is only left with seawater in it.
That is true, but I would imagine that a certain amount of mixing takes place in the pipe, so that under normal conditions the water column will always be contaminated to some extent.
