stefan_r
- Joined
- 16 May 2001
- Messages
- 753
- Location
- Southampton & Greece (Chios)
The perennial question I know.
Am looking at replacing my lead acid batteries, 4 x 110ah, with Optima gel batteries...Optima only do up to 55ah each.
Lead acid Varta (so good brand) £115 each delivered.
Yellow Optima £150 each.
So:
(1) Will I get a 50% longer service life from the Optimas to cover the 50% uplift in price from Lead to Gel? Don't enjoy replacing batteries at the best of times.
(2) If you read the bumpf the Optimas are okay to have a lower ah as they run longer at a 100% output and then sharply drop off to almost nothing whereas Lead slowly loses output. So on average does a 55ah gel give me something nearer to 100ah to compare to the Lead battery? Or is that rubbish??
(3) Have I missed anything?
I am using these in a motor boat so topping off the charge is no issue...I am not bluewater cruising.
The use I will have is largely anchor for a few hours, an have typical domestic consumers. Fridge couple of amps/hour; lights negligible; Eberspacher D3 couple of amps; water pump for sink/shower; electric bog 20 amps but unles it's a curry night very infrequent use!
All in all say 30 amps/hour?????
So:
