Opinions, please - Hydraulic oil
Jegs
7 Jul 2007
The boat has a vetus hydraulic steering system. Originally VG 32 was specified but now they say VG 15. My questions area: 1 Is there much practical difference between the two grades? 2 Is mixing them likely to cause problems?
Hopeful thanks,
John G
Both are biodegradable vegetable based hydraulic fluids.
One has a viscosity of 15cst at 40C the other 32cst at 40C
Mixing them should cause no problems .
I have no idea why a thinner oil is now specified!
I'm going to go out on a limb and suggest that Vetus change the recommended viscosity every couple of years so folk bother to change it; degradable oil tends to do what it says on the tin.
Hyd. Oil
Gentlemen,
Thank you both for your replies - Vetus £12.95 per litre, local £5.99.
John G
I use just a standard oil from an industrial fittings suppler about £8 for 5l. They also made up a set of pipes at around 25% of the cost of Vetus ones.
The thinner oil will greatly reduce the wheel / system drag in cold weather. Have used ordinary industrial hydraulic oil for 20 years , with no ill effect.
