deuc02
Anyone got any tips or hints as to how to get the Mac version of OpenCPN to see NMEA data. Have all NMEA 0183 data coming through an Actisense multiplexer into a USB port on a Mac. Have downloaded and installed the latest driver from the Actisense website. All good so far. Run OpenCPN and go into the toolbox. This is where the problem starts. Think the OpenCPN manal might be for an older version as it refers to
When the driver is installed and the device connected, start OpenCPN, select the Toolbox and click the GPS tab. Open the "NMEA Data Source" menu & select the the device from the list. It is not always obvious which is the correct one, but in general the device will have a name starting: "/dev/cu." or "/dev/tty.". Some manufacturers make it obvious, like "/dev/cu.MiniPlex-99000125", but others may be more generic, like: "/dev/cu.usbserial". Set the "NMEA Baud Rate" to 4800 and click "OK". If the correct selection has been made, you should see the GPS status icon change from red to green.
So go to toolbox and then to connections as no GPS tab that I can see. Can't see a NMEA Data Source menu but hit the Add Connection box. The only selectable data source is /dev/cu.Bluetooth-PDA-Sync
Am I missing something obvious, or looking in the wrong place. Any thoughts, ideas or fixes gratefully received
