oakleyb
Which do you prefer and why ?
Much easier connections to and from and the ability to broadcast the nmea data to other devices in network.
I prefer MXMariner on my Android tablet, with in app purchased UK charts and converted BSB/KAP raster charts via MXCart. It has low power consumption and can be used in the cockpit.
On the laptop I use OpenCPN due to ability to use old worldwide CMap93 vector charts and the active system development. It can also be used on Linux as well as Windows.
Seaclear is only used for converting scanned in paper charts to BSB/KAP charts for the above two, as it has been overtaken by OpenCPN in features.
I also scan my charts for use in Seaclear which gives me the benefit of being able to print specific A4 'sacrificial' copies in high resolution to sleeve and use in the cockpit.Having the bitmap/WCI also means that you can make make particularly significant edits based on the NTMs,using a graphics editor.
As I'm lucky to have an up to A1 plotter I can also combine the bitmaps accurately and print work-over paper copies for longer crossings. e.g. at varying tide states.I also use OPEN CPN with CM93 but the lack of drying heights is not particularly helpful on the East Coast.I appreciate there's a proper route now for using updated charts with CPN.
Seaclear is useful if you already have a scanner setup, and particularly so for your local area where you can keep on top of NTMs and will repeat the same outgoing routes.You can also introduce inserts of any scale,calibrated accordingly and I find it moves flawlessly from A4 to A4.
If you're not or cease to be an enthusiast for file handling then there's also the useful offerings from Visit My Harbour.
