Durcott
Hi Folks,
I have two bilge pumps on my (bilge keel) boat - one manual diaphram type, pumping out to the usual sort of outlet, and an electric one, which pumps out into the boat's outboard well in the stern quarter.
The problem I have, is that when the boat is floated off her river mooring, sometimes she takes on a severe list. I reckon the outlet from the electric pump gets submerged, and then water siphons in until the hull unsticks from the mud. The water does pump out again, but the damp and mud (or worse) is taking its toll on the cabin. I reckon at worst I get 40 or 50 litres in the cabin, which sloshes around due to the acute angle until she rights herself.
So - apart from the screamingly obvious - move the ***** boat - I'd like to consider putting in a valve or an anti siphon device.
I could merge the output from the electric pump into the pipe feeding the manual bilge pump, taking advantage of that pump's internal non-return valve, but then the electric pump would have to work 'through' the diaphram,
OR I could fit a non-return valve to the electric pump, and hope that it doesn't get blocked in an open position,
OR I could fashion an anti-siphon device, aka the thing you see on sea toilet plumbing now and again - not that I have a great deal of freeboard to work with.
I suppose I could add a vertical loop to the electric pump's output, but I've not got a clue how much 'head' a typical pump can drive.
I've got no experience with bilge pumps, and all of my options feel like bodging. Has anyone got any advice to offer?
Jeff
Jeff
