one way/non return valve
AndrewJ
16 Apr 2003
Virginia USA
Anyone know anything about a one way valve for a bilge pump or any other ideas. I pump my bilge but what's left in the hose drains back when I shut off the bilge pump. /forums/images/graemlins/confused.gif
HeadMistress
9 Sep 2003
USA
A non return valve in a bilge pump discharge is not a good idea, Andrew...'cuz if it clogs (and bilges are often full of "glop" than can clog it) or fails, your bilge pump won't be able to pump out any water.
Use a manual "dinghy bailer" and a bucket or wet vac remove the water the bilge pump leaves behind. Yes, it's extra effort, but no one (except the dealer) ever said that maintaining a boat can be effortless. In fact, it's actually a LOT of work! /forums/images/graemlins/tongue.gif
HeadMistress
9 Sep 2003
USA
Scarlett, why would you need a check valve in the holding tank pumpout? I can't even visualize where it would go or what it would accomplish...which is NOT to imply that it has a use...I learn something new from boat owners every day, some of which is very useful.
scarlett
21 Dec 2002
French Canals 2007 on, Hull most of winter. previo
Hi. Being in Greece and the boat being equiped with an RM69 bilge pump as the thing for the pump out job, it was being immobilised with tomato seeds. The RM69 is designed with flap valves which are very susceptable to being kept open by such little things.
Having to overcome this I bought what was available locally, the Plastimo gadget, which is fitted with valves which are like bird beaks. This is fitted just above the tank top level. This worked ok but when the new Plastimo pump arrived I threw the RM69. Now all is well.
The boat has a high lift from the tank to the outlet. The check valve also helps speed the pump out process by preventing any 'drain back'.
squidge
6 Jul 2002
East coast
bought one today from TCS chandlery £2.99. Keep them clean and they are OK as nothing will come through the sieve on the pump big enough to cause a blockage. I have one on each bilge pump line to stop one filling the other as they use the same outlet.
HeadMistress
9 Sep 2003
USA
First I've ever heard of tomato seeds causing problems in a holding tank overboard discharge pump...I'd think anything that could cause problems in that pump would cause problems in the toilet pump first. That is, unless your waste tank is also doubling as a gray water tank and they're going down the sink drain into the tank, not through the toilet. If so, that's a major no-no...black and gray water systems should never be combined any way because of the risk of e-coli and other germs and viruses found only in waste migrating into sink drains, contaminating sinks and surrounding areas.
However, you've actually made a better case for rinsing out the tank, pump and lines several times a year than you have for a check-valve in the line. Not only to flush out sludge accumulation in the bottom of the tank, but because waste contains animal fats that build up on gauge senders and inside pumps and hoses....and your check valve, 'cuz I'd think that anything that can cause problems in the overboard discharge pump would also cause the same problems in a check valve.
scarlett
21 Dec 2002
Hi . There are only solids and sea water from the toilet going into the holding tank. It maybe something that you don't experience but at least one of us is incapable of digesting tomato seeds!
The holding tank was spotless recently when it was removed for system overhaul. I also flush it at the end of season with fresh water. If it works don't mend it, certainly if it is fouled with 'solids'. Sorry.
