TheBoatman
I started the day with a couple of pieces of toast and peanut butter, the toaster refused to work properly giving me first under-done, then near burnt toast. I then went off to the club to drive the travel hoist and lift 3 boats, 2 twisters and a cruiser, all went well in that dept, members happy, boats ashore and nicely tucked up for the winter. Came home and decided that the grass really needed to be mowed one last time, so did that. SWMBO said that she noticed that there was a nasty "wet patch" on the wall in the hall, I had a look and decided that a central heating pipe under the floor was leaking so I set to and started to cut out the floor to locate the pipe and the possible leak. I was about 2 minuites into to this when I cut the central heting pipe with the chisel, water spurting up the walls. Turned off the water and drained down the heating. With SWMBO, we mop up the water. Oh well I thought that's it, I'll carry on and expose the pipes and find this leak. 2 miniutes later I "kango" through the gas main. More panic, shut off the main, open the windows and doors and generally vent the place. Phone Transco who send out an engineer. He tells me that he won't/can't undertake such a job and caps off the main and advises me that I need to contact a registered Corgi plumber to solve the problem and I can't turn the main back on until a registered corgi engineer say so.
I'm now sitting in a house with no gas or central heating?
SWMBO says she's going to the chippy to buy tea and leaves me to it.
Whilst shes away I get out all me old and defunct plumbing equipment and set too?
I've repaired the pipes and I am now waiting for the Corgi plumber to arrive in the next 2 days to say it's OK to fire the systems up again.
Why is that I can do plumbing for any one else, I do it when I'm installing machines for my business, but the moment I need to do it for myself everything goes belly-up?
Is it because it's a Monday?
Or is it just me? Either way I'm bloody freezing and I can't have a fry-up breakfast today!
Boo Hoo
Peter.
Boo Hoo
Peter.
