One Diesel and two outdrives! It has been done!
Nautorius
24 Jun 2003
Gibraltar, Small Boats Marina
From the USA where they are realising that running two 8.1litre petrols is not great and that by replacing with a single diesel and twin outdrives the future may be brighter!
Article is BOATTEST
Here are a few snippets from Boattest;
"To date, Mastry Engine Center in Tampa, Florida has quietly installed in 15 test boats of all types what could become a revolutionary new propulsion system for certain marine applications. In the process, Mastry has become the nation’s leading expert in the technology. In the beginning it was thought the best application would be for trawler-type boats between 35’ and 50’, but when Mastry plopped a Yanmar 6LY3 480-hp in a 27’ high performance design, it got people thinking about the advantages of the system in small boats too. "
"By the time Mastry got the 27’ Porsche which had been originally built in the 1980s, it was already neutered: the 454 Magnum MerCruiser engines had been taken out. Mastry says that with those engines its WOT was 79 mph. Mastry installed a 480-hp Yanmar 6LY3 diesel on the centerline and the three “Geared Up” boxes weighing a total of 350 lbs. Total: 1,761 lbs. The two 454 magnums had weighed about 2,260 lbs total, so the boat now weighed nearly 500 lbs. less with the single diesel. With the “Geared Up” system Mastry was able to turn the engine around which meant that the pulleys and belts were now at the transom and the drive shaft was low going forward.According to Mastry, the top speed of the 7200 lb. 27’ Porsche with the single diesel was 62 mph, with best cruise at 47 mph at 2600 rpm, getting 4.35 mpg. Not bad for a high performance boat. "
Looks good to me!
Paul /forums/images/graemlins/smile.gif
Many years ago I skippered a Solaris Catamaran that had a single engine driving a hydraulic pump that fed two individual sterndrives. It was a PITA as the power to one drive decreased as you brought in the power to the other.
Interesting post and development /forums/images/graemlins/smile.gif
It has to have merits for anyone thinking of getting rid of two V8 petrols and replacing them with a single diesel.
Adds even more value as only one diesel engine is needed, trying to source a pair of secondhand units would not be easy.
I am not so convinced on the merits for a new installation., but couple it with a pair of IPS pods and you would create another space.........not sure if it would be a usable space or just another waste of space /forums/images/graemlins/wink.gif
Thats me trying hard not to put my thoughts across again /forums/images/graemlins/smile.gif
[/ QUOTE ]Precisely my thought.
A plain vanilla single outdrive is obviously simpler, lighter, more efficient and less expensive.
This equipment can only make sense where there are already two big holes in the stern, with outdrives attached to them.
Which, tbh, is what they seem to have designed the unit for.
not really as many arguments about twin versus single is that if you foul a prop or outdrive with a single unit you cannot make it back
ok you have the remaining of the equation which is engine problem, but many will tell you this happens much less to prop or a drive accident
this technology is still in its birth, we see what happens with it
I have a single engine - Perkins 135C - driving 2 props through hydraulics, with seperate controls for both props - also bow thruster and windlass - this system is great both props have same power to each one and the control is excellent. I do not see why the same system could not be used with much more power
Roj M.
I have a single engine - Perkins 135C - driving 2 props with seperate controls for both props - also bow thruster and windlass - this system is great both props have same power to each one and the control is excellent. I do not see why the same system could not be used with much more power
Roj M.
