Laysula
I need to replace the domestic battery, is it best to get one 180 ah or two smaller ones of 110 ah each giving a higher capacity and costing less?
Makes no real difference electrically, just depends on what fits best in your locker. A single battery would tend to occupy slightly less volume than the same capacity in two, but the shape of the pair might actually fit better.
there may well be a consideration of the cost/weight/space requirement for the extra battery cabling and connectors.... and fusing.....
It may be the same as engines. If having full power/capacity is important, buy one big one. If having some power/capacity is important, buy two smaller ones.
I really don't think it makes much difference. Each lead/acid cell generates about two volts. A load of them are connected together in series (and possibly also parallel) to form the overall battery bank. How you arrange the plastic boxes around that collection of cells matters only from the point of view of physical handling and dimensions.
as for the argument about aeroplanes is that why the mosquito with two engines is called a fighter bomber?
Surely the engine thing is just coincidence. Bombers had to be bigger to carry the bombs and to have the range. In the early 1940s, the only way to get enough power for such an airframe was multiple engines.
If it weren't for passenger and regulatory redundancy requirements they would go for one engine on the biggest planes. As it is of recent times we have seen many regular twin engine operations over vast oceans simply becuase engines are so reliable.
