Piers
Anyone know an easy way to change the anode on this genny without allowing a half litre or more of seawater to flood the base? The anode is at the back of genny in the most inaccessible position possible.
It is absolutely critical with mdkal to install genset with space at right hand end. If they mounted it with right end inaccessible then tut tut. It's the only onan I can think of with this problem. Most others have the heat ex at the front.
It might be better and should be pretty easy to buy rubber hose and 1 inch grommets, and mount the heat exchanger outside the genset casing where it would be much more accessible.
If you never change the anode the heat ex will last 5-6 years
You could do what I do and have a tee in the raw water inlet, with hosepipe connection, and flush genset w freshwater when you aren't going to use it for a week. I have hosepipe inside e room to make it easier. Then you wouldn't need anode. You could even do it remotely if you bought a couple of motorised valves and fancied a little project.
Hi Piers, three weeks ago I did this on my MDKAZ. I use a wet & dry hoover, start to loosen the anode then run the hoover & hold the tube at the side/under the anode & gently loosen away letting a slow stream of water shoot into the hoover. Doesn't take long & voila no water in the tray.
A heating guy showed me this trick for taking radiators of when the drain cock sticks as they all do. Works a treat.
Paul
zero risk of any problem if you know what you're doing; some risk if you're a bit incompetent, though you'd need to be unlucky. . A comment you could make of boating generally!It's me Mr "awkaward question "
What's the risk of waterlocking the engine cylinder (s) ?-I mean the fresh water in is so strong it backs up in the exhaust manifold *and /or - from turning gen off too early before water off ? -and exhaust valve (s) is open = fills up
Or t,other way - @ start up - drying the impeller from not synchronising Gen on with tap on ?
Pressure from strainer s just passive 1m below W/L ish or less ., impeller just sucks sea water from strainer .
Hose pressure any thoughts ?
* assuming water leaves the Geny set via the exhaust manifold(s) .
