Aeolus_IV
Have just got the boat onto the hard standing (just in time for this gale, good timing eh?), and have a couple of questions about prop shafts and cutlass bearings.
I'll start with the bearing, or rather the residue of bearing which had bonded intself to the shaft. At the point in the shaft which would be in the bearing the shaft had a thin layer of very hard black substance bonded to it. This wouldn't clean off with spirit so have to carefully scrap it off. Underneath this the shaft had a slight coppery colour to it. This has all clean off very nicely with some metal polish, so you cannot tell now where the bearing was. The bearing itself looks OK and normal to me with no obvious wear.
I'm assuming that this is not normal, and that the bearing was either too tight at some point, or didn't get sufficient water lubrication while in use. What is the forums opinion and experience?
Now for the stern glad, or rather, evidence of wear on the shaft from the stern gland. Here the shaft has been polished by the stern glad around the shaft. Cleaning the shaft with metal polish shows that I cannot polish the shaft as well as the stern glad. But also that the surface of the shaft in this area is now slightly uneven. I doubt that I could see the unevenness, but I can feel it. The stern glad is a simple grease and packing one - in the time we've had the boat (a couple of years) it has never leaked and I've never tightened up the packing, only ensured a continious supply of grease while the engine is running.
Again, is this normal, or is there a problem I should be sorting out while I have the chance?
Thank you in advance,
Jeff.
Jeff.
