Ominous electric failue of a Volvo 2030
Chanquete
18 Jan 2013
Buenos Aires, Argentina
Hello!
This time I am asking for enlightenment
Today I switched on my Volvo 2030 and as usual it started immediately running evenly regularly without problems. Oil pressure also OK.
But my instrument panel indicated no electrical charge (12 V instead 14V) and the rpm instrument showed mistakenly strong (inexistent) rpm oscillations.
The belt of the generator was OK turning without problems.
The no charge alarm began to sound.
I switched off the engine.
I am trying to understand the failure.
Anyone knows this type of failure?
Thanks in advance.
Chanquete
Hello!
Thanks in advance.
Chanquete
Could be a number of things:
Bad connections
(Multi pin connectors on engine wiring ????)
worn alternator brushes
defective regulator
Bad connections
defective regulator
I think the defective regulator can be ruled out (rpm indicator also affected).
Probably brushes, commutator or field windings.
Only sensible course of action, alternator out and into an auto-electrician for bench-test and repair. that should also sort the possibility of wiring mal-connection.
commutator ??
This happened to me once when on passage and with the light of a torch in the darkness I found a loose connection somewhere on the alternator, in fact it had come right off. I don't know what it was but all was well after reconnecting.
Me too. Same symptoms and the above solution
Me too. The terminal post in question is probably the one you can't reach with a (very small) spanner unless you take the belt off the pulley and swing the alternator away from the engine. It takes the return from the panel as a whole, the tacho and the alarms. In extremis, the electrics will stay dead when you try to start the engine, probably when you really need it. Ask me how I know this.....
I had the same thing happen with my Volvo 2030. I groped about at the back of the alternator and found a tag without a wire on it on the alternator. More fishing about found an unconnected wire with a spade connector at the end of it. I put 2 and 2 together and connected the wire to the spade connector and I had charging batteries. Might be a good place to start before taking things apar.
Vics,Charles reed, Bilgediver, Johanalison, Old Varnish, Grumpybear and Billmacfarlane I thank you all very much for your clear suggestions.
Next week I will inspect carefully the zone around the alternator hoping to find only a connection problem.
Muchas gracias!
I don't know if it's the same as my 2002 but I had very similar symptoms and eventually a total electrical failure and a dead panel. I traced it to the fuse block on the top of the engine. I just moved the connector the the next pin along and all was well. Weirdly I moved it back a few days later and it worked in the original position so it hadn't blown the fuse.
