ex-Gladys
Well, I followed the recommendation here to use the above when fitting the new loo... What a revelation! It slipped onto the seacock tails Sooooo Easily! Can do no more than thoroughly recommend it.
I have only two slight downside observations I have, is that the OD is quite a lot larger, so you need to use hose clips the next size up, and the rubber finish, makes it a bit of a bugger to feed through behind cupboards etc., but having said that, I'd NEVER go back to the old white stuff again.
An observation on the statement Vyv made in previous heads threads, he is absolutely right, the inlet hose was not scaled at all, the outlet one was, and a lovely coffee brown colour at that, although only a mm or so thick.
