Old treadmaster glue
That'd be ok on smooth surface - what about rough patterned surface? Some kind of abrasive I'd imagine or is there a chemical method?
From the treadmaster forum
Once you have sanded the Treadmaster and Epoxy away, you will be left with a fair amount of cleaning up to do! The sanding dust should be swept up, and the deck surface will need to be cleaned prior to replacing the decking; we recommend using Acetone or Propanol to clean the surface of the deck, it is essential that you do not use White Spirit, this will leave a greasey residue that will affect the future bond. If you have a metal deck, the surface should be lightly abraded and then cleaned before applying new Treadmaster. The cleaning is essential to ensure that any dirt or sanding residue is fully removed before starting again.
