noswellplease
I recently bought an old Trintella 11 and I'm presently upgrading. I wonder if anyone might have some advice in deciding which through hull fittings to replace over the Winter. I guess if they are solid brass they should be ok but some galvanised ones look a bit iffy. Ay words of wisdom on this would be appreciated. I guess the same holds true for a disused debth transponder should it be pulled and glassed over? If removing do you simply attack from outside with anglegrinder and replace with similar sized fitting? Any help would be great,
