Old Lewmar 40 ST winch Drawing needed
HermanD
Active Member
3 Oct 2004
Holland
Has someone a exploded vieuw off one old Lewmar 40 ST winch produced in 1979.
From 1982 and later there is enough to find on the web.
But not the older ones.
I has a topcap with 4 bolts for removing, but a difference with the from 1982 model
is, it has a set off pawls on the bottem of the main spindle.
The newer onces have the pawls in the gears.
Need the vieuw before servicing these winches.
regards
HermanD
Is it this one?
I've got the service manual (volume 6) with that drawing in but it says for the 40ST introduced in Jan 1984 so it's probably not the right one as the OP said '79.
I can easily email the pdf if it is right .
Thanks Owol and Troubadour
But that is a later type with the pawls in the gears.
Mine has one sets pawls on the central spindle and
one set pawls in one gear.
Perhaps Lewmar had not good documentation in
the old days
Herman
