bigman1
Hi,i have had a lot of trouble with the oil pump on my perkins 4107,the oil relief valve stuck open twice,removed it and came o the conclusion that the spring was weak(very old engine)so i made a 3/8"long spacer to increase tension,fitted it to engine hey presto no oil pressure,removed it ,made drive shaft with 1/4"tang to fit slot on pump shaft to drive pump with power drill fitted pump in vice,lots of oil pressure,so now i have pump with oil pressure on bench and none in engine,iam realy pissed off wish i could afford a new engine.Any ideas.Ronnie.
