oil change on perkin 4.107
barneyboater
New Member
7 May 2013
hi all,
just a little help getting ready to change the oil and head gasket on my 4.107 been told there is a manual pump fitted to get it out because the bleed nut is right out the way but not really sure what i'm looking for any help or pic of the unit would be great.
thanks Carl
hi all,
thanks Carl
If you cant find an oil drain pump, should you be doing the head gasket :o
on my 4108 Low Line the drain pump was on the stbd side of the crankcase
