richardabeattie
So many debates in the past but here I go again. (Raw water cooled 2GM20). With the boat ashore the standard methods seem to be either:
Run the engine on fresh water to flush out (some of) the salt and long enough to open the thermostat - at least 10 minutes - and then run in the antifreeze.
Or alternatively remove the thermostat, replace its cover and clamp off the bypass hose before running in the fresh water and then the antifreeze - a much shorter run time as the engine does not have to warm up.
But what's wrong with simply disconnecting the bottom end of the hose leading up from the impeller to drain the block, reconnecting it and then pouring the antifreeze mix straight into the top of the thermostat housing?
