wotayottie
my boat has a volvo 2030 inboard diesel with a Sterling digital voltage regulator attached to the alternator. the engine ran fine on the 2 hour delivery from winter storage to my pontoon berth but as soon as the boat was in the lock and engine idling, an alarm started beeping. one beep about every 5 or 10 seconds but very regular.
when the engine was revved up the beeps stopped. they returned when I got to my berth and the engine was idling as I tied up but when I stopped the engine and re-started it maybe 10 mins later, no beeps.
now the alarm on the volvo instrument panels is wired such that it beeps for any of oil pressure, water temperature and charging whilst the warning lights indicate which one is the problem. no warning lights lit up ( and yes they are all working) and in any case the alarm is designed to beep continuously not at regular intervals. so I wondered if it could be a broken wire vibrating in and out of contact, but that would not beep regularly as happened. instead it would be intermittent. low oil pressure or overheating would trigger a continuous beep.
the boat has not been out since then but I have on two occasions run the engine for an hour or so tied to the pontoon. not a beep but then I didnt have the courage to run the engine at 2500 rpm whilst tied up ( only 1750 rpm) so the heat soak would not have been the same as on the initial trip.
any ideas? the volvo dealer is as stumped as me because all problems should give a continuous alarm not intermittent. and finally, the alarm itself works continuously as its designed to do if I turn on the engine electrics but dont start the engine so the alarm isnt faulty either.
