Peter
Hope someone can help me with this alternator problem, symptoms are. When the ignition is turned on the alternator gets hot, without starting the engine. With ignition on/off there resistance to rotation on the alternator, which causes the engine to stop when idling and making it difficult to start. Remove the plug from the alternator this resistance goes and the alternator rotates freely. Everything seems to be wired up correctly, good voltages on the alternator +ve terminal and battery voltage to the exciter (I think that the correct term) when the ignition is turned on, good earth, general engine wiring in good condition, although I have some doubts about the way the engine panel has been wired up, although I don’t think this is the problem. This is a new (reconditioned) alternator only run for approx ½ hr. The first alternator was changed for a similar problem.
Might be an odd one, I have not heard of it before, hopefully some answers please
Peter
Peter
