chris-s
I'm refurbishing the mast head on our little Pegasus 700 which is made from some folded aluminium sheet bolted together with stainless bolts. As expected, at this age there is some corrosion around the bolts loosing the anodisation. So after cleaning it all up, priming and painting it I'm wondering if it is worth reassembling using some nylon washers between the nuts/bolt heads or not. I would use duralac as well anyhow.
Chris
Chris
