onenyala
I am in the process of fitting a Polyvee belt sytem on my Beta BZ482 to replace the original Vee belt.
I have to fit new pulleys to the engine cooling pump, the crankshaft end and the alternator.
It seems to be a relatively simple job. I have fitted the new pulleys to the crankshaft and the cooling pump but I am unable to release the nut which secures the pulley to the alternator.
The alternator is off the boat and I have been able to hold the pulley in a vice. Despite using my not inconsiderable weight and also gently heating the nut it just wont budge.
Unfortunately the nut is recessed into the pulley so it cannot be cracked or sawn off.
The engine is new (2years) so it is not a case of corrosion.
Any suggestions out there.
