Ruffles
Had the prop off at the w/e to do the cutless bearing. Shaft drive with a taper. The dome nut was quite tight to get off but the prop came off with a puller fairly easily.
When I put the prop back on I knocked it on to the taper quite gently with a pin hammer and a wooden block. When I then put the dome nut on I found that I only needed to tighten it a quarter turn for the split pin hole to line up. In other words the nut is not on that tight. Certainly not as tight as it was.
Is it acceptable to put a washer between the prop and the nut? The alternative is to drill another split pin hole in the nut.
BTW I greased the taper before fitting the prop. Is that a mistake?
Thanks,
Rob.
Thanks,
Rob.
