simonfraser
no luck searching on this forum
what is the nut size on the rear end in the cone of a DPE duoprop ?
tnx
tnx
Cannot be a 19mm nut on a 20mm thread as the thread is a larger diameter than the flats on the nut, for a 19mm head size the thread must be M12 and not 20mm as the video states, onless it isn't a nut, but a bolt instead.
...., remove the prop on a regular basis and grease it again, else it gets stuck, experience ...
