Nuova Rade Zefiro vertical holding tank
syvictoria
12 Oct 2009
Europe
Hi. Has anyone fitted a Nuova Rade Zefiro vertical holding tank? If so, what was the quality like please? And the wall thickness? I'm trying to find a slightly larger offering than the Tek Tank 40L vertical, and ideally with a smaller vent. Can't quite fit the Tek Tank or Vetus 60L tanks in annoyingly! It must be a bulkhead/vertical version. Thanks.
Have you asked Tek tanks to make you a custom made tank? Better materials and you can have the fittings placed where you want and may be able to get even more capacity as you are not restricted to fixed rectangular shapes. Inevitably more expensive but the best. I have had two such tanks made and in each case maximised the capacity.
I bought and fitted a 40L a couple of weeks ago. It was a new install on a head which previously had direct gravity pump out with no tank. Installation was relatively simple once I plucked up the courage to make the holes in the deck and hull for the pump out and vent connections. The tank seems robust but time will tell. Check what connectors you are getting with it - mine didn’t include to deck pump out or the vent connectors and I couldn’t get originals in Turkey and had to have them made up.
