superheat6k
OK so now the colder weather is arriving I decided to test out the Eberspacher D4. This worked just fine at the sea trial, but has not been turned on since.
So I discover the thing is completely dead. Here is my fault finding and discovery trail ...
Power 12vdc +VE is present at both fuses, even with the supply isolator switch off - Odd !
I then check all the plugs on the wiring loom - all are tight.
I then notice the thick brown wire from the supply loom runs back to the port battery +VE. The same battery I changed about 2 months ago. I then realise the brown wire is in fact the -VE. I have also checked this on the Eber wiring diagram.
So this explains why I have 12v at the supply fuses. These I also checked are good.
So some numpty (ssshhh - this thread author) has connected the brown negative to the + VE.
So now I have corrected the incorrect connection the numpty (above) caused, but still nothing.
What I am struggling to understand is where the incorrect +VE supply could have flowed to - as with both the normal supply +VE and negative connected to +VE there is no circuit.
I can't see from the diagrams any other -VE connections that could have caused a reversed circuit through the controller.
I have not checked that the pump -VE routes via the heavy brown -VE, as this is the only other -VE feed on the heater. If I find this is routed separately to -VE am I likely to have toasted the controller ?
Finally I have noticed a separate fuse on the Control supply feed (5a +VE), but to access this I have to remove the 240v protective perspex covers. So if this has blown, how ?
Might have a broken D4 available for spares shortly !!!
