stuhaynes
Now this is only a thought. 230vAC from 30HP engine
30 HP @ 2000RPM max., cruising, say 1500 RPM Single 'V' pulley. 4 cylinder diesel.
What are the options for a 230 volt AC generator including min cost of equipment?
I'm not looking at this too seriously, I just wonder.. What are the dynamics of, say for instance, something that can produce 3.5KW to run maybe a washing machine or 1KW immersion heater or a standard electric kettle? Though not all at the same time...... Just curious
I'm pretty sure that a single 'V' pulley drive won't hack it.
Given the use of our current boat, this is not a necessity, but if we change our boating patterns, which is possible, we may be glad to be prepared to use the engine to provide our 230 volt needs. We have a 1500 watt inverter, but only 4 'house' batteries, wired to provide 220AH (@24 volts). As has been said to me before in a previous question, this is nowhere near enough. We don't have space to place more than 2 more batteries max., and that is still not enough..even if the inverter was. Our alternator is 60 amps max and 24 volts, if that has any relevance.
