firstascent2002
Just seems like a lot of oil to me? But never used flush muffs with a two stroke before. This picture was taken 10 mins after the engine had been run up for 15.
Is there any manufacturer who recommends 100:140:1 is very rich, what engine is it? You should run at normal ratios 100:1 most likely,
Piers
Some did suggest it for a while but reverted to 50:1 after problems developed. Commercial version of engines never recommended 100:1.
Pretty sure most Yams are 100:1
I think you're right there - most grudgingly agreed you could run on 100:1, but privately recommended nearer 50:1.Is there any manufacturer who recommends 100:1
I wonder if you missed a not out there?I think you may be right although ITYWF LS is correct when he says that 100:1 is ??? recommended for commercial use.
My manufacturer recommends 100:1 mix. Is that enough oil?
Absolutely NOT! DON'T DO IT! That's plenty to lubricate the motor under IDEAL conditions with a HIGH QUALITY 2 cycle lubricant. The problem comes after use - the lack of adequate oil for storage on the internal bearings, rings, and cylinder walls leaves your motor wide open to IMMEDIATE internal damage, and shortened service life.
