B
bob_tyler
Having had a new Beta 13.5 fitted to replace the Vire 7 in my Invicta 26 I have a small problem as the boat is considerably faster under power..
When I tried the engine flat out, after a gentle but variable revs running in period, I found that my cockpit drains let water uphill into the cockpit as the bows lift and the stern squats. The drains slope from the cockpit sole in a straight line, sloping downwards and out through the tramsom. They are glass fibre tubes, about 1½ inches in diameter moulded into the hull.
I fitted flap valves externally in the winter - the rubber type that external water pressure should hold shut. They have reduced the ingress but not eliminated it.
The exit holes in the transom are normally above the waterline but obviously dip below at maximum speed.
Any suggestions? The only solution I can think of are plugs at the inner end but this would look very untidy and rather defeat the self-draining cockpit. Being me, I would probably forget to remove them on going ashore and the cockpit would fill up with rainwater by the time I next went afloat. (A bit like launching a dinghy without putting the bung in! I'm sure we've all done that)
I don't believe that it is a weight problem as, when moored, the stern is no lower than before, just a problem at speed.
Help please! /forums/images/graemlins/smile.gif
