rotrax
Hi-I have just recieved one of these Chinese copies from an ebay supplier for £44.99 delivered. It is well made and so far all the bits appear to be interchangable with the genuine Racor.
I am very immpressed so far. I cleared a little fraze from the mounting holes, ran a tap into the threaded holes for the unions-the powdercoating has got on the threads-and threw away the supplied element and fitted a genuine Racor one.
It has the internal floating ball which cuts fuel supply off should water get in in large quantities. The O rings may be of questioable quality, but genuine Racor elements come with these, so easily rectified should they prove inadequate.
Excellent value for money. I will fit it soon with a 10 micron element after the OE Racor 500 which has a 30 micron element. This should extend the life of the 10 micron Yanmar filter, which is a bugger to change and also expensive.
The Racors are top loading so are much easier and cleaner to change or service.
Service report when it has been in use for a while.
