Hillbilly
New Member
Not as exciting as the title may indicate....
I have twin D6 330’s on shaft (2012). Port side is super smooth and quiet. Stb, not so much. When I engage idle and anything over,, I get what a can only describe as a slight grinding noise. I also get slight vibration above 1500 RPM. Any thoughts what this could be? I’m thinking along the lines of cutlass bearing, or knocked / out of balance prop. Stern glands are water fed, no sign of a leak.
Engine is smooth as the port side when increasing revs in neutral, and gearbox oil fresh.
Any thoughts much appreciated, cheers.
