LinTeal
I am getting a "slapping" noise from the propellor shaft area on my Sadler 29 with the engine in gear..Assumed some line/netting around shaft. Donned my face mask and had a look but the shaft/prop was clear.I noted that there was a little play in the shaft where it went through the bearing in the P bracket.Could the noise be a result of wear in that bearing or it may be the rope cutter.Any thoughts.If the bearing needs to be replaced is that a difficult job?
