Noisy Jabsco Par max2 fresh water pump
Mandarin331
27 Oct 2008
North Norfolk
Last year we bought the boat with a VERY noisy Jabsco water pump. After investigating we found it was mounted on a loose peice of wood which vibrated against the hull.
I've now re-positioned it on a solid bulkhead exactly as per the manufacturers instructions, but it still makes a noise like a pneumatic drill (albeit slightly muffled), guarateed to disturb the neighbours on a quiet morning. Otherwise it works perfectly.
The manufacturers description calls this pump 'quiet' ! So I'm wondering if my definition of quiet is different to theirs.
Does anyone else have any experience with this pump, is this normal or is there something wrong with it.
Neil
I think that's what I've got. I wouldn't call it noisy but it isn't quiet. Wouldn't wake the neighbours but would wake me in time for early morning cuppa. I should be so lucky /forums/images/graemlins/frown.gif
Same here I would not call it quite. Sometimes when I have let the tanks run dry the pump continues to run. So I am glad that I can hear it and remind me to fill the tanks.
I ended up with mine mounted on rubber buffer feet on a wooden board, which is then stuck to the hull side with a thick layer of silicone. Then I had to stop any bit of hose from vibrating against structure. It's a lot quieter now.
Hi Shamal,
At last, a question I can answer.!
I'm nowhere near my boat right now so cannot quote the make of fresh-water filter that I have under my galley sink, but I cleaned out my water tank in the keel & changed the filter & dutifully screwed the new filter onto the fixed top fitting until the marks lined up correctly.
The noise was horrendous, reverberating throughout the whole boat. I started dismantling pipework under the cabin sole thinking the pump had sucked up some dirt from the tank, which took me several hours, (the filter on the Par Max 3 was clean) I eventually tried screwing the new filter right past the two marks-as far as it would go- & that fixed the problem. Damn thing had been sucking in air for a few days. Very quiet now, as it had been from new.
Jock
well at least your is working.. /forums/images/graemlins/mad.gif
I sent mine back for service to Jabsco and got it back after £70+ were spent on it. Fitted it and it still did not work. Not impressed.
