mikeakc
Hi all,
I wonder whether you could advise me on how to get to the bottom of why I have no oil pressure reading on my BMC 2.2.
I was changing the oil filter element as part of my annual winter service. It was a royal pain in the backside to re-assemble the oil filter body (bolt through the bottom) and when I restarted the engine having completed the job, the gasket blew out (obviously I hadn't managed to seat it properly), squirting oil across the boat and making a god-almighty mess. Choice words were directed at the engine and I instantly regretted throwing my sacrificial towel out of the boat onto the drive moments earlier. Following these fun and games I decided to purchase a conversion kit for a spin on filter which I installed with no issues (I pre-filled the filter with oil too). I added some blue hylomar gasket sealant to the mount for good measure and checked and corrected oil levels. The next day I nipped up the bolts on the filter mount body and started the engine - the spin on filter weeped oil. I couldn't get it any tighter by hand so I purchased some filter pliers, gave it another turn and it no longer weeps - oil level in the engine still fine.
However, upon running the engine the pressure still shows zero PSI. I concluded (incorrectly it seems) that I must have blown the sender or gauge during the previous gasket blowout incident, so I purchased a replacement durite gauge and sender, fitted these tonight but STILL no oil pressure reading! When I turn the ignition on, the gauge jumps from its off position up to zero, so it has power and is responsive.
Does anybody have any idea where to go from here? I was planning on removing and re-fitting the spin on filter mount, but this seems unlikely - if that was the problem surely I'd see oil coming out somewhere?
Any advice would be very gratefully received!
Thanks,
Mike
p.s. this is what the conversion kit looks like - Screw Oil Filter Conversion kit BMC 2.2 2.5 Engines Leyland Commodore Commander | eBay
Thanks,
Mike
