No diesel from HP pump Yanmar
yanmarrob
New Member
29 Aug 2025
Hi. We are trouble shooting on a Yanmar 4JH2-DTE. There is no diesel on the injectors. No air lock, good filter, priming pump ok, stop solenoid ok, confirmed pump cam turning. What have i forgot to check here?
You do not mention bleeding the injector pump. Although injector pumps usually self bleed , sometimes theycdo nor and need a little help.. There us a bleed screw on the pump for this purpose.Once the fuel pump is free of air, slack of all the injector HP pipe connections to prime through to the injectors .
Might also be worth checking that the pump rack moves when the speed lever at the helmets moved .
You did not make it clear if you were slackening the injector to pipe connection to carry out bleeding, however if you miss this then your problems could be expected.
