vas
Yanmar 2cyl engine for my MASE generator rebuilt is finished, going back in early next week.
Scrapped the coolant temp and oil pressure switches and replaced with proper pressure and temp sender. Further I'm adding a coolant pressure sender and if I manage an EGT sensor.
All that go in yet another black box which also will be operating the starter, the fuel stop valve and a custom job (using another stop solenoid) that will be pulling the governor to idle when generator starts and before it shuts down (to avoid having the rebuilt the motor in another 1000h...
So big (probably white) box with 4 relays an arduino board and a few chips, job done.
Now, since my original box/board starting the MASE has died and took the dash display with it, I need to control the generator from my custom touch screen that operates the fin stabs.
I can have a custom sentence to operate it from the touch screen and even have a two way comms with the generator, no problem.
Wonder if for temps/pressures/etc I should use ENGINE 3 as a node to do that and be able to present it in N2K dash or don't bother and do only custom sentences...
So basically q is for JFM or whoever else has his gen in N2K
cheers
V.
PS. I should at some point post a whole report on the N2K tools I've built with the help of Timo's libraries..
cheers
V.
