NMEA splitter (numpty question)
All_at_Sea
3 Aug 2005
Hampshire
With one GPS receiver and two items onboard requiring the feed can l get a splitter/box for this? Or is it as simple as a load of wires all joined together in a cats cradle behind the chart area? Is there such a thing as a NMEA distribution box?
You are all probably using these things but l have never seen one.
i used a block connector in a sealed box
You can simply solder them together or use a choccy block in a sealed box of some sort.
The basic rule for NMEA is that multiple listeners are OK (can parallel as many in as you want essentially), but as soon as you get into the realms of multiple talkers onto the NMEA network, then you need to be looking into multiplexers etc.
I've certainly heard 4 as the limit, but it will depend on the equipment and the wiring actually involved.
Coincidentally I just renewed my advanced level NMEA installers cert and this was one of the "starters for ten" in the exam, the official line is a maximum of 3 listeners per talker. A simple project case with a barrier strip using ring terminals is a good and reliable method for distribution, Raymarine used to make a nice little one at not a lot of money but I haven't seen one for a while.
