NMEA Comms Question
Major_Clanger
15 Oct 2016
Home is Suffolk, boat either Suffolk or Cornwall
I've just plumbed-in a Garmin 451 plotter and am using the 0183 output for a NASA GPS repeater and Icom M423 VHF. The repeater works fine but the radio isn't receiving any info as showing 'no position'. I've double-checked that I'm using the radio's positive 'listening' wire. Any ideas what I've done wrong?
Thanks for any input.....
andsarkit
27 Aug 2015
Dartmouth
You probably need to connect both 'listener' wires.
Green = B, yellow = A. It is a differential connection not referenced to ground. If one of the wires has been grounded it may possibly work as the NMEA implementation is sometimes loosely interpreted but it is not the proper way to do it.
PaulRainbow
16 May 2016
Suffolk
Usually just connecting ICOM signal -ve to Garmin ground will do the job. There's not really any practical alternative.
I agree with that Mike. In fact, in most cases it works if you just connect the Icom signal neg to its own -12v power cable. Neither method is how it was supposed to be done, but as you say, no choice.
