neilandshiv
I want to convert NMEA 0183 depth and speed/distance to the analogue signal that comes from a B&G Hecta piezoelectric depth transducer.
Actisense's DST converts from older transducer signals to NMEA 0183 but I can't find anything that does it the other way round.
So my questions
1. Does anyone know what these old transducers output. Eg Is it something like 0 to 5 volts for 0 to 100m.
2. I'm sure I could program a Raspberry-Pi to read NMEA 0183 depth/speed/distance and get a the values in a variable in the program but can anyone help with how to get an analogue signal out of the device.
Ok before someone says Why - here's the answer.
We have an old B&G system on the boat. The instruments below and repeaters above are great, but the log transducer housing is failing and no spares are available.
I want to fit a single transducer eg Airmar DST800 and drive the existing instruments. I want simple separate depth and speed and not some multi function display with loads of options.
Fitting Garmin / Raymarine instruments above and below deck to recreate what we have now
is too expensive.
One other option for the log is the NASA Easy Log which accepts NMEA 183. NASA also have a wind instrument that will input NMEA 183. And the Yacht repeater multi function display that does wind, speed, distance, depth and lots of other stuff but for some strange reason they don't do an "Easy depth" instrument on its own that reads NMEA 183.
I think they are missing a trick here as with versions of their clipper instruments that read NMEA and display individual items such as Wind, Speed/Distance and Depth they could provide an option for much cheaper repeaters for Raymarine / Garmin etc systems where there instruments are £300+ each.
So my questions
is too expensive.
