Lyulph Hesling
Active Member
I redid the varnish on my Sunbeam last year. I used Blakes Classic inside the hull, and it has worked very well, bright and clear, and no damage.
I did the covering boards and coaming with 4 coats of International Clear Wood Sealer (a two pack epoxy) covered with 8 coats of Blakes Classic Varnish. It has worked badly. The finished work looks "muddy" and a bit dull, but more importantly any little ding results in the Wood Sealer breaking clear of the wood, going yellow, then wet, then black. It is too brittle for use in a boat. To revarnish you have to rub back to bare wood, wasting all the effort of all those coats! I am going to have to strip it all off and redo the work, very annoying.
I note this fits in exactly with the varnish tests reported in the March 2011 Classic Boat. Two pack wood sealer or varnish may be okay in areas with little potential for damage (in cabins or houses perhaps), and it does build up quickly, with several coats a day (so boat builders like it) but I am never touching the stuff again! I will just use the Blakes (or Hempel, as it is now) Classic.
