Rum_Pirate
I have been given (nothing as expensive as a free boat) a RIB and an engine.
Sounds great.
The RIB is a somewhat aged unit.
The engine is a Tohatsu 2.5 outboard.
However, I describe these lightly, the rib has two main issues.
FIRST The transom has come 'unglued' from the side tube.
Question 1 : Is it OK to fix this with 5200 ?
If it is not advisable to use 5200 then what adhesive is recommended?
SECOND There is a puncture at the bow on the inner (easily accessible) face of the tube at the bow
Question 2 : Is it OK to fix this with 5200 ?
Perhaps a vulcanising tube patch would be adequate?
The outboard has a (minor) issue.
The fuel cock on the engine has broken off in the 'on' position. The previous owner tried a temporary solution of setting a small coin in 5200, where the cock turn was located to stop the fuel flowing out.
The engine now currently does not run. :ambivalence:
A new 'US$20.00' fuel cock is on its way from St.Maarten as I type. [may get it at end of this week - life in the Caribbean].
I can only hope that none of the sealant has travelled into the engine innards.
Please not that this RIB is not intended for future heavy usage.
Mainly trips of 100yards/metres with 1-4 people and a cooler aboard.
One last thing, how do I know if the tube on the RIB is Hypalon or uPVC (or other) ?
Sounds great.
